Premium Membership β™•
Grab a 15% discount on the PRO Plan with code RMS15 and sharpen your skills with our LV/MV/HV power engineering studies.
Home / Download Center / Electrical Engineering Books and Technical Guides / Electricity generation, t&d guides / Load flow analysis of 138/69 kV substation using ETAP (Electrical Transient & Analysis Program)
Improving voltage profile of feeders
In this study, a load flow analysis is performed to a 138/69 kV substation using ETAP software (shortener for Electrical Transient & Analysis Program). The scope of this report encompasses the load flow results, and explains how these were used to implement changes on the feeders that resulted in an improved voltage profile.
The substation layout and equipment choice were provided by Black & Veatch (B&V) as part of a Senior Design project. In this context, the load flow study is performed for different operating conditions or scenarios to determine what control measurements are necessary to prevent system breakdown.
The results of the load flow study for the different scenarios, will be substituted into power flow equations destined to improve the power factor of a given bus. The equations define the relationship of the real and reactive power with the desired power factor.
They yield the updated size of fixed or switched shunt capacitor banks required to compensate the inductive effect of the loads. To verify that the theoretical results are accurate, the load flow is performed with the updated parameters for the capacitor banks.
As introduced earlier, the power flow study for this substation will be performed on ETAP. The acronym ETAP stands for Electrical Transient and Analysis Program.
This software is a comprehensive platform for the design, simulation, and protection of electrical networks.
Load Flow Simulation for Unchanged Conditions
ETAP not only provides solutions to substation designs, but also specializes in generation, transmission, and distribution of power systems.
The software relies on predictive simulation. This allows the user to perform analysis using real-time system parameters and may also simulate β€œwhat if” scenarios to predict equipment malfunctioning.
ETAP also uses preventive simulation, which allows the user to see any automated alarms and warnings. These alarms and warnings are based on events that could potentially occur (generator outages/contingencies) and corrective action will be suggested. It analyses are always verified and validated against field results, real system measurements, and hand calculations.
The one-line diagram of the electrical system in question is composed by several pieces of equipment, each with a specific function. All of the components for this substation are high-voltage components.
Some of the most important components are:
  • Power source,
  • Disconnect switches,
  • Circuit breakers,
  • Capacitor banks,
  • Transmission lines,
  • Power transformers,
  • Potential (voltage) transformers, and
  • Current transformers.
The layout for the substation and the operation parameters for each component on the one-line were specified in the documentation provided by Black & Veatch, with the exception of the transmission line parameters. The process of choosing the most suitable type of conductors for the transmission lines is also discussed in this thesis.
Performing load flow analysis
For a deeper understanding of this thesis, it is important to cover important information about the load flow analysis. The load flow is analysis is performed to determine whether the system voltages operate within the specified voltage limits under normal or fault operating conditions.
It is used to determine the voltage drop at different points of the system, the voltage reading at each bus, and real and reactive power losses through each branch and feeder. ETAP creates warnings if a feeder bus is below the nominal voltage.
Likewise, the load flow study is often performed to identify the need for additional generation units, and the addition or replacement of capacitors and/or reactors to maintain system voltages within specified limits.
Title:Load flow analysis of 138/69kV substation using ETAP software – Vanessa Abadia Gomez, College of Engineering, Department of Electrical Engineering, University of Arkansas, Fayetteville
Pages:23
Download:Here πŸ”— (Get Premium Membership) | Video Courses | Download Updates
Suggested Reading – Automatic transfer switch between three power sources (analysis of schemes)
7 Comments
  1. SHAILENDRA PANDEY
    Mar 25, 2025
    I WANT TO KNOW THAT IN SUBSTAION DESIGN WE USE CONDUCTOR FOR CONNECTING THE EQUIPMENT.HOWEVER IF WE MAKE SLD IN ETAP THERE IS NO OPTION OF CONDUCTOR. SO WHAT WE SHOULD USE FOR FEEDING THE EQUIPMENT(LIKE CABLE TRANSMISSION LINE AND IMPEDENCE OR NOTHING).KINDLY SUGGEST ME SO WE CAN GET ACCURATE RESULT.
  2. Ben Junior Fomba
    Jan 14, 2025
    Dear Concern,
    I do work for an electrical corporation in my country as Transmission and Distribution Maintenance Electrical Engineer. My interest is being drown to learning to operate the software (ETAP). Should i register now or can you get me an online class?
  3. Mostafa Kamal
    Aug 12, 2020
    Dear concern
    I am going to install one 2000 KVA substation in DHAKA , Bangladesh. now my question is
    1. Can I set it in the Basement floor instead of Ground Floor?
    2. Can I install 610- kva Generator outside the building ?
    3. What are the test to be conducted before I take over the setup from the supplier? The equipment are fro Siemens, Germany.
    Best Regards
    Mostafa Kamal
    12, August, 2020
    • Syamprasad
      Feb 05, 2024
      I am from India and trying to purchase the course on surge protection device ( SPDS ). But I am not able to go to the check-out.
      Is it required to have a premium membership for purchase of any course???
      Please reply with complete details or a payment link.
      Syam Prasad
      [email protected].
      India
  4. Gebrehiwot gebru
    Aug 10, 2020
    i need this software i have taken this software in fiveth year when i was a studen. anyway this is fantastic course in ece especially power stream
  5. Bonginkosi
    Apr 20, 2020
    Morning sir/madam
    I would like to request more information about fixing transformer if ever is not supplying power to another, also any kind electrical problem, thank you
    B. Mdazo
  6. zeggai amine
    Aug 19, 2019
    Thank you for this information
    Best regards
